  1. in VCDEasy, i am trying to add a final mpeg sequence which is an mpeg still that simply reads "Insert Disc 2" or "Insert Disc 3" however, when the movie is played back, it absolutely will not display the message. in vcdeasy, the settings that i'm using in the interactivity are as follows:
    on the last chapter of the movie, the next sequence is set to the mpeg still
    the mpeg still is set to wait infinite, and next sequence = disabled, return = videoCD END. i'm wondering if maybe i should set it to wait 30 seconds rather than wait infinite, but why wouldn't it work if setting it to wait infinite might be causing a problem??
  2. I have had no problems with putting the MPEG still. If I remember correctly I put a 15 second wait and then to VCD END. So you should try that. Anything from 15 second to 30 seconds is good enough. Your choice really.
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
  3. thanks for the info. any ideas why it won't work when set to "wait infinite" - i will try the 15 second limit though and see how that works out. although i would prefer "wait infinite."
    j
  4. Originally Posted by flyguyj
    j
    Do not know the details. Unfortunately I do not have enough experience with VCDEasy. I haven't got around to figuring out what each setting does. Try sending a PM to delphi.stuff (mod for VCDEasy) or Vitualis or Adam or Sefy. They all are great guys and be willing to explain.
    Regards,
    MO, US
    I use "wait infinite" for change-disc stills and it works fine.
    A man without a woman is like a statue without pigeons.
