  1. I've managed to get the time and date from the video that I've captured from my camera into a sub file using DVSubMaker.
    now i want to add the sub to the movie permanently.
    the problem is, I want to add the sub at the bottom left of the movie and not at the botoom center as it's on default on most softwares.
    with which software I can add the sub and choose the area it will be placed in the movie?
    Apr 2002
    The State of Frustration
    What is the sub file format (.srt? .ssa?, etc)?
    Hello.
  3. .sub
    but i can convert it to another format
    Apr 2002
    You could try loading it into Sub Station Alpha. Then select Styles..-->Define. Then select subtitle and right. Save as a different .sub file name and try it with your new file
    Hello.
  5. 10X
    you've helped me alot!
    just another question and that's it....
    how can i add to the ending(in the time I mean) of all lines at the sub file the value 1?
    I what to do it so the date won't blink.......
  6. But how do you rip in the *.sub file to your VOB files?? I'm working on that but whit no luck.
