whats up?
i wanted to know if any of you have ever encountered thisp roblem or know of a way to fix it:::
I am making a project with meastro, the main menu is a live action clip. Roughly about two seconds after the clip starts, thats when i have the In loop and highlight buttons, button appear. After the clip is done it is supposed to just endlessly repeat (made sure loop was checked). i burned a sample dvd-rw disc it works excellent on any homedeck machines, it works fine on the pc using the "windows media player classic:. But for some reason power dvd after the menu plays once it will not repeat it, instead it goes straight to the next menu screen.
in Maestro, if i set the highlight button to time 0;0;00 so the highlights appear once the clip starts, then powerdvd will repeat the menu like it is suppose to. Normally this would have been ok, but i do not have the titles on the screen the buttons go to appear for like 2 seconds.
What is worse is the people/friends i am making this for all pretty much use a labtop for their dvd watching and have power dvd as their app. Does anyone know why power dvd might be doing what it is doing?
I then took the burned dvd-rw test and tried playing it in my pc to see if powerdvd would work it correctly--no dice it still does the same thing, goes right to the next menu screen instead of repeating the dvds main menu.
