To date I have used two authoring programs to create my DVDs.
ULEADs DVD WORKSHOP & SONIC FOUNDRYs DVD ARCHITECT.
Why is it that when I burn discs with DVD Workshop, the elapsed time of the clip is shown on the standalone. (ie, if I shuffle through the display options on the player I can get time remaining, length of movie etc) but when I create the Discs with DVD Architect, all the information I get is "PLAY"
Is there anyway I can use IFOEDIT to fix this?![]()
I had the same problem. I upgraded DVD Architect to the newest version, downloaded from Sonic Foundry site and problem gone!
George -
This is a problem (feature?) with most single VTS authoring programs.
If you set the movie to repeat play it will not display the time on the DVD Player.
So don't set the main movie to repeat.
Read this thread for more info
http://www.sonicfoundry.com/forums/ShowMessage.asp?MessageID=185712&Page=0 -
In Maestro:
If i set PREVIOUS and NEXT (in movie) back to MENU this shit happens. You need to set the last "end action" to back to Menu (not the next and previous)
JVC (GR-DVF21) DV in/out - not showing on DVD player ?
By Roamingdoc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2011, 10:46 -
Showing Live Time in scenes with Vegas Studio 10
By HoosierGuy in forum EditingReplies: 4Last Post: 23rd Mar 2011, 15:01 -
Capturing video to my PC and a standalone DVD recorder at the same time
By fuzzblaster in forum Capturing and VCRReplies: 4Last Post: 10th Sep 2010, 15:14 -
subtitle time codes showing in movie
By jacktheflash in forum MacReplies: 2Last Post: 28th Apr 2010, 23:17 -
video clip not showing the time
By Natalie in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2009, 12:31
