I've tried using vDub but no luck.....when I open first file it just gives me a blank screen. I have Main Concept codec installed, and have tried using nadub as well, but still no joy.
Can I do this in TmpgEnc ? If so, please point me to a good guide as I'm struggling big time.
Ultimately, I want to be able to combine 2 xVid .avi files in to one file and copy to DVD-R in DVD format.
Results 1 to 9 of 9
Cheers
handsy -
First, when you first open a file in virtual dub you will see a blank screen. Drag the button at the bottom of the screen to the right and you should see a picture. If not, load your film into gspot or avicodec and see what it says. Let us know.
Thanks so far guys.......
laddydaddy, which button...there are loads, plus when I click any of them down the bottom I get "VideoSourceAVI error: The source image format is not acceptable. (error code -2)" !
Gspot reports it as xvid with ac3 audio.
Tommyknocker, haven't tried avisynth yet, will try and report back
Cheers
handsy -
The button I speak of is actually right above all the loads of buttons. It is to the very left above the stop button. You also have ac3 audio which will give you a problem unless you have the latest version of virual dub.
Hrrm, screen grab attached.....I have the latest version. Which button ?
Cheers
handsy -
Just look at the buttons on the bottom of the screen. Look at the one at the very left. Above that is a rectangular button which has a long white rectangle next to it. Drag that button to the right. Also, do you have the xvid codec installed?
Portable app for combining AVI files
By cowboyup910 in forum EditingReplies: 3Last Post: 27th Oct 2011, 03:58 -
combining two .sub and .avi files into one
By agassi in forum Video ConversionReplies: 1Last Post: 8th Jul 2010, 16:59 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 13:47 -
Combining avi files in virtualdub mod
By buckethead in forum EditingReplies: 2Last Post: 11th Aug 2009, 20:22 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05
