Hi
Bit of a newbie here. If you have a dvd writer that is not region free
and you dont want to play back dvd on your pc .( so you dont install playing software) And you make a backup with the likes of dvdxcopy
then burn back to dvd+r etc will you be still be buged with region free crap???
Thanks DAZA
No, probably not.
I say probably because my experience of utilities that check for region coding is they sometimes "miss" a reference in one of the IFO files (they seem to check the first one and not any subsequent ones).
I have just answered a similar question elsewhere on the boards with IFOedit - do a search for that and my name and you should be fine.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Making a Region 1 Player Region Free. Can't find code.
By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 09:28 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
Thanks for ya help Garry'
