Hi, I'm new to the macworld, and I'm trying to learn how to make copies of some VCDs that I have and give them to my parents. When I put a vcd in the superdrive, I can view the contents of the vcd, but do not know which files I will need to convert into bin/cue files. If someone can help, I would greatly appreciate it. Thank you very much.
For this method you would
1. insert disk
2. open toast, choose COPY menu and then go to file and SAVE AS DISK IMAGE.
3. once that is done, just burn the disk image by dragging it to your toast icon.
brun -
Just in case you don't have Toast you can use Disk Copy.
1. Go to /Applications/Utilities/Disk Copy
2. Go to the Image Menu in "Disk Copy" and select "New Image from Device"
3. Save it whereever
4. Open the image with "Disk Copy" and from the Image menu select "Burn Image""First god damn week of winter." --R.J. MacReady
Newbie needing help downloading adobe video
By pistolpete1979 in forum Video Streaming DownloadingReplies: 4Last Post: 31st Aug 2010, 17:32 -
Newbie needing help converting MKV to AVI
By deadman36g in forum Video ConversionReplies: 12Last Post: 8th Aug 2010, 14:06 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 11:01 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20
