  1. i got a zip file with some .ape files in it. i duno what to do aout it cos i dun have the .ape program..i search the net n download the program monkey audio but it seems to exit everytime i use it..i really fed up cos i really want the data in the zip files..anyone can help me? thanz alot
  2. Member steptoe's Avatar
    I'm assuming it is an actual 'monkey' audio file, and not an archive format that is also called .ape, but then again this is rarely used, so it will probably be the audio data.......
    Go here, assuming you are using Windoze that is ??
    http://www.monkeysaudio.com/
    Or use one of the many audio converters out on the market. Personally I prefer to use dbPowerAmp, as it has a very nifty DSP add-in which is well worth a look at, especially the adaptive normalize feature for boosting poor volume recordings, and I know the .ape format is supported, as a plug-in
    Also, its cheap to register, but is also fully functional as the trial version
    Go here :
    http://www.dbpoweramp.com/dmc.htm
  3. I've tried using dbpowerAmp but itz just a converting program..what i need is what to do with the .ape files that i downloaded. Im not sure whether the files are in what format but the size of each files is about 30 over Mb
  4. APE - Monkey's Audio Lossless Audio Compression Format
    APE - Winamp Plug-ins AVS File
    http://filext.com/alphalist.php?extstart=%5EA
    hope that helps
