this guide will teach you how to put a complaint vcd/mpeg1 onto a dvdr and play on a standalone dvd player without having to rencode. baaldrick! i love you!
Tools Needed
Tmpgenc
Tmpgenc DVD Author
Step 1.
1. open tmpgenc and exit wizard
Step 2.
1. Go File>mpeg tools
Step 3.
1. Click the de-multipex tab
Step 4.
1.under input click browse and load your vcd mpg
2.doubled click on video stream and audio stream to save them(preferably to dekstop)
3.exit mpeg tools
Step 5.
1.under audio sorce click browse and load the .mp2 file that was just produced by de-multiplexing
2.click ES[audio only]
3.under output click browse and choose where you want to save your new .mp2 file
4.click setting
Step 6.
1.under sample frequency choose 48000
2.click ok
Step 7.
1.click start
Step 8.
1.go file>mpeg tools
Step 9.
1.click multiplex tab
Step 10.
1.click mpeg-1 system(automatic)
2.click add to load your new .mp2 file that was just made and load the .m1v file
3.under output click browse and choose where you want to save the new mpg
4.click run
5.click close then exit tmpgenc (you can now delete all the old files except the new mpg that was just made
Step 11.
1.open tmpgenc dvd author and select create new project
Step 12.
1.Click Add File and load your mpg
Step 13. Optional for chapters if you want no chapters just hit ok when the dialog pops up
0.click chapter cut edit
1.use the scroll bar as to where you want your chapters
2.when you find the specific spot click "add current frame to chapter" (you can add multiple chapters)
3.click ok
Step 14.
1.To label your track double click untitled track 1
2. type what you want your video labeled
3. hit ok
Step 15.
1. click create menu
Step 16.
1.click which back ground you want
2.label your title and movie by double clicking them
3.click the next page and do step step 6 part 2 again
4.click output
Step 17.
1.click create dvd folder
2.click browse to where you want your dvd folder to be
3.click begin output
Step 18.
1.click "open dvd writing tool"
Step 19.
1.select write speed
2.choose recorder
3.label disc
4.click write dvd
DONE BaALDRICK I LOVE YOOOOUUUUUUUUUu it's chupes ))))))
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 13 of 13
Punk Forver
Actually… you can skip all this multiplex/demultiplex steps…. Just import mpeg1 file in DVD author, it will convert audio from 44100 to 48000 automatically.
I've done many vcd to dvd conversions and the only problem I see with chupes guide and the suggestion from akm74 is it doesn't work if you have movies that have been joined, either by yourself or before you "aquired" them
If you find your finished files are cut shorter than the originals then this is the problem.
You have 2 choices, either re-encode them as vcd in tmpgenc as one file and take the hit on quality or skip the demux-remux with tmpgenc part of the guide and instead run the vcd mpg's straight through (s)vcd2dvdmpg 1.1 (the version with besweet not the latest version without it). This has the ability to "paper over the cracks" and allow dvd author to see it as one file of the correct length. -
If I have multiple MPEG-1's say like 10(10 episodes say...) Do I have to join them all first? Or can i have 10 files on the dvd?
Also nutstoyou, do you know any other ways of making a MPEG-1(not2) DVD compliant cd?? -
Keep your 10 episodes unjoined to reduce the risk of any audio sync problems.
Assuming you have the new version of tmpgenc dvd author proceed as follows.
Load your first episode by clicking create new project then clicking the add file button. After the compliant file info box appears click ok to close it and then click add new track over on the left before clicking add file to select your next episode. Same for all the episodes, add new track before add file for each one.
When they're all loaded click on the Untitled Track text on each little box on the left and give each track a name corresponding to the episode.
With 10 episodes then at the create menu page open the drop down list on the left and select New Theme and on next page open the Layout of the Track menu list and choose one of the Layout 10 themes. -
Step 16 part 3 I think is either a typo or just plain wrong(actually it's from the orig author guide, but the steps werent edited). If you do as it says and go back to step 6 part 2 then you would end up back in mpeg tools on tmpge. Also of note on step 6 is that if you cannot get the audio to re-sample at 48000, you need to open the LOAD tab and then EXTRA folder, then UNLOCK. I know whats going on somewhat, but a newb may get his brain melted.
Hi,
I have two serieses of cartoons (13-13 episodes) extracted from VCDs. This means 13-13 mpg files. I have created two tracks and added these 13-13 mpegs as chapters to each tracks. (Of course, I converted the audio to 48 kHz, as it is written above.) Then I chosed the Blue menu scheme and created the menu. After burning the disk I was not able to play the second track at all. Even the submenu was not displayed. I could play the first track perfectly. Only a little problem: after the last chapter was played it did not come back to the menu or did not continued with the next track.
Please, help me how to fix this problem, how I can create the second track playable.
Thank you for your help in advance. -
When i try to add my mpg1 to dvd auther it is rejected because of the
framerate is 23.976.
Most of my vcd's are ntsc film at 23.976 fps. This was because the
original dvd was at this frame rate.
Do i need to convert the video in this case.The one eyed man is king in the land of the blind. -
Hi there,
i'm a newbie and have been trying to copy my mpg movies onto dvd. I have tried this giude and all goes well and i get my meg2 file but when i play it back the sound drifts after 3-4mins and by the end of the 40 mins it way off. I also get the errors message "****** packets cause buffer underflow" when mutiplexing the mp2 file back with the video. i have tried using VirtualDub to change the sound file but again i get the drift when playing back the movie. I have only once got the sound to stay sync'ed to the video and thats when i let TMPGEnc plus run its wizard but the file size was 2.6G ! If any one can help please. I'm from the UK so we use Pal but i not sure if that would effect this !I was born this way blame my mom !! -
I wrote a guide at www.lordsmurf.com that takes a different approach, and I find it easier and with less steps.
Thanks i have had a look at your site and will try a few things out
hi again, i had no luck same loss on the audio. My source file is video 1150kps 29.970fps 352x240 4:3 and the audio is 224kbps 44100hz
when i covert the audio to 48000 what bit rate should it be converted at ?I was born this way blame my mom !! -
Ok, If I follow the steps of this guide "Compliant vcd/mpeg1 to dvdr" than how many minutes of VCD MPEG1 video can I fit on a single 4.7Gigabyte DVD-R Disc?
Thanx.
Xenogear900@yahoo.com
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 20:49 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 18:30
