While trying ot run menu maker (version 1.5), I get an error indicating that menumaker cannot be found. Hard coding pathnames into your program? Shame on you :P
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Exception: ProcessRunner::Run(): no such Program: C:\Program Files\Badgersoft\SVCD2DVD\DVDMenuMaker.exe
at g.a(String A_0, String A_1, String A_2, k A_3)
at f.e(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.3300.0
Win32 Version: 1.0.3705.0
CodeBase: file:///c:/winnt/microsoft.net/framework/v1.0.3705/mscorlib.dll
SVCD2DVD
Assembly Version: 1.5.1336.21117
Win32 Version: 1.5.1336.21117
CodeBase: file:///D:/winapps/SVCD2DVD/SVCD2DVD.exe
CodeBase: file:///c:/winnt/assembly/gac/system.windows.forms/1.0.3300.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/winnt/assembly/gac/system/1.0.3300.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/winnt/assembly/gac/system.drawing/1.0.3300.0__b03f5f7f11d50a3a/system.drawing.dll
Xceed.FileSystem
Assembly Version: 1.0.29.0
Win32 Version: 1.0.29.0
CodeBase: file:///D:/winapps/SVCD2DVD/Xceed.FileSystem.DLL
Accessibility
CodeBase: file:///c:/winnt/assembly/gac/accessibility/1.0.3300.0__b03f5f7f11d50a3a/accessibility.dll
RegistrationSDK
Assembly Version: 1.0.1218.19534
Win32 Version: 1.0.1218.19534
CodeBase: file:///D:/winapps/SVCD2DVD/RegistrationSDK.DLL
System.Xml
CodeBase: file:///c:/winnt/assembly/gac/system.xml/1.0.3300.0__b77a5c561934e089/system.xml.dll
System.Security
CodeBase: file:///c:/winnt/assembly/gac/system.security/1.0.3300.0__b03f5f7f11d50a3a/system.security.dll
9d61b5hk
Assembly Version: 0.0.0.0
InProgress
Assembly Version: 1.5.0.0
Win32 Version: 1.5.0.0
CodeBase: file:///D:/winapps/SVCD2DVD/InProgress.DLL
MagicLibrary
Assembly Version: 1.7.4.0
Win32 Version: 1.7.4.0
CodeBase: file:///D:/winapps/SVCD2DVD/MagicLibrary.DLL
FolderBrowser
Win32 Version: 0.0.0.0
CodeBase: file:///D:/winapps/SVCD2DVD/FolderBrowser.DLL
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///D:/winapps/SVCD2DVD/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///D:/winapps/SVCD2DVD/Interop.SHDocVw.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
I don't hard code....
run dvdmenumaker.exe, close it, then run svcd2dvd.
problem solved.
if you read the forums b4 slating me you'll see that this is an installer issue which i am working on.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 17:59 -
Is this a bug of ConvertxtoDVD?
By jackwolf in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 11:13 -
Bug in vegas 8.0c ?
By seifer almasy in forum EditingReplies: 12Last Post: 17th Mar 2009, 14:16 -
AutoMKV Bug .........
By RVD2720 in forum Video ConversionReplies: 11Last Post: 14th Mar 2009, 01:26 -
Possible Bug?
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 25th Jul 2007, 04:55
