  1. I wanna burn this dvd that i have on my computer. The problem is i dont know how to, i see all the tutorials, but i dont know which one i want. When i extracted the movie, it created two folders VIDEO_TS and AUDIO_TS. Can anyone help me and tell me what i use and how to burn this so it works in a dvd player. Thanks
    Jul 2003
    Ontario, Canada
    If your computer profile is correct you need a DVD writer and they usually come with a software package to write to the DVD.
    Nero is a good software package and there are several others as well
  3. I have a bunch of burning programs, but how should i burn it? sould i burn it as a video file? there are two folders, what should i do with them.
  4. Anyone? Its futurama season 1 that i have. I extracted all the stuff and it came out to be 2 folders. One is VIDEO_TS and one is AUDIO_TS. what should i do with that or what program should i burn it with.
    Mar 2003
    Kansas City MO
    Well raptor, its as simple as this. Read the guides to the left on this web site. All the work has been done for you. Take the time, do the research and if you get hung up then post. Okay?
    Aug 2003
    Florida
    Okay, I have a question......I am burning a dvd9 to a dvd5.....i am running xp as well.....now what i used is dvddecypter to rip the main files, used ifoedit to get sectors, then used dvdshrink to get it under 4.7 gb.....now my problem is i am ready to burn...do i need to make an image of the the video_ts.ifo file?? this is where i am stuck at...the simplest part....i havent played the files since ive shrinked them with dvdshrink. can anyone tell me what i need to do now?? thank you
    Mar 2003
    Kansas City MO
    May I suggest a more direct route in the future. Use DVD Shrink alone to rip as you put it and compress in the same step. Follow the guide for DVD Shrink and you can't go wrong. The resulting files that it creates (where you tell it too) can be burned using Nero or Record Now. What burning programs do you have and version? By the way you should be able to play the individual VOB files with a player such as Power DVD.
