The jury is still out on the pros and cons of one format over the other.
But,just out of curiosity,what format is being used for studio DVD movies?
"Today is only yesterdays tomorrow"
neither, a commercial DVD is actually Pressed layers between plastic. Its not a recordable format, it manufactuered.
However the DVD Forum which set the DVD Standard is the same one that supports the DVD-RW format. Make of that what you will. -
The format is called DVD-ROM.
You can create 100% compatible DVD-ROM disks with Ricoh based DVD+R/W drives and an app called DVDInfo. Once you set the Book type to DVD-ROM they are compatable with all set top players."Terminated!" :firing:
DVD+R won't play, have I bought the wrong format? - New post/problem 15/12
By yultie in forum MediaReplies: 20Last Post: 17th Dec 2010, 14:59 -
Copy movies/youtube clips to a DVD format
By RubyBlu in forum Newbie / General discussionsReplies: 4Last Post: 1st Jun 2009, 20:32 -
Store bought DVD movies rarely play
By Mark Girvan in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2008, 14:12 -
scenes missing from store-bought movies
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 16:53 -
Will a US-bought HDTV display movies from my PAL DVD player
By aguinebe in forum DVB / IPTVReplies: 8Last Post: 3rd Jul 2007, 12:06
