OK, I just got an Optorite DD0203 DVD+/-RW drive. I am using Fuji DVD-R's that come in the 50pack. According to DVDInfo, they are Ritek G03's. I burned a DVD at 2x speed in my DD0203 using Nero 6 with the newest firmware (2.17) that plays in the following:
APEX AD-1500 standalone
APEX AD-500 standalone
Playstation 2
Samsung SD-612 (PC internal 16X DVD Drive)
It will NOT play in the following:
KLH KD-1220 standalone (from what I read is supposed to read everything -- gives me "BAD DISC" error
Samsung SM-348B (PC internal 16x DVD Drive w/CD-RW) (oem) -- just keeps trying to read it indefinitely.
Here's the thing that's bugging me. Rather than chalk this up to incompatibile media, I have a DVD-R that is ALSO identified as a Ritek G03 that was NOT burned in the Optorite that WILL work in the SM-348B drive and the KLH 1220 standalone.
I know that the discs are from different batches, but I don't know why they wouldn't both work?
In Nero, instead of choosing DVD-VIDEO, I chose DVD-ROM (UDF) and unchecked Multisession. I read that these steps increase compatibility.
What am I doing wrong, or is the Optorite just burning fickle discs? What should I try to do? Thanks!![]()
Results 1 to 27 of 27
First thought is try diff media with the Optorite. Also try using DVD-Video in Nero. And try diff Burning software.
Doing all these steps will help you identify if the Media is the problem the Burning Technique or the Hardware ( Burner or Players )
Yes you use a few disk but helps for future, as will lower chances of making a coaster later on.
Honestly too many other possibilies left to say that the drive is the problem.
There are some issues with the drive, but there are some issues with all drives, each one has it own quirks.
And one last obvious point it could just be a bad disk. It happens -
I have this burner. I just got some Ritek G04 DVD-R and was very surprised to find that this media won't play in my new Sony standalone. I know that people generally get good results with Ritek media in this burner. And I know that people have used this media with good results in my player. I've burned the same image to a DVD+RW and it works fine.
I haven't had a chance yet to determine if this batch works in other players.
Figuring all this out is quite a nuisance. -
Nero does not list the Optorite in its listing of compatible drives. It does, however, list the Accesstek DD0203 as being compatible with Nero 5.5.10.32 and above, and the Sanyo CRD-BPDV2 as being compatible with Nero 5.5.9.25 and above. Supposedly these two drives and the Optorite are all identical transports. Even Optorite claims their transport comes directly from Sanyo.
I'd be interested in knowing if there's any AccessTek and/or Sanyo owners out there having problems in Nero. -
Thanks for all your help. As suggested, I just burned the same disc using DVD-VIDEO and it now works in the KLH KD-1220 standalone. The one thing I think that must have caused it not to work was the lack of an AUDIO_TS folder in the first one, since I used a different burning method that didn't create one.
The new DVD still won't read in my Samsung SM-348B DVD+CD/RW combo drive. Like the first one, the light rapidly blinks like it is trying to read it indefinitely. As mentioned, the other RITEK G03 disc not burned in the Optorite plays in the drive. However it should be noted that this disc was not in the same batch as the ones that I am burning now, and it wasn't burned in an Optorite drive.
Do you think that 5/6 players playing it is pretty good for my 2nd DVD burn ever? Should I just let it go and chalk it up to incompatibility, or could this be a problem with all Optorite drives or just mine?
Thanks alot. -
astonGuest
I'm also very suspicious with DVD-R burning with my optorite
many tests, many questions
burn many differents -R media (Bulkpaq, Memorex, Verbatim, Q 4x) and everytime I can't read those dvd in a PC reader (differents brands tested : Liteon 163d, Pioneer 116 & 119R, Samsung), but they play very well in standalone player (Toshiba, Pioneer 535, Sony). Also tried different software.
When I make the same tests with +R media (Imation, Verbatim, Memorex), they play flawlessly in my PC.
The problem is the same with data dvd (impossible to read -R media onto my PC, no problem wih +R)
The big mystery is that the same -R media, written with another burner (a Pioneer) will be read without any problem.
Any clue ? -
The Optorite site recommends 6 +R brands, 7 +RW brands, 3 -R brands and 2 -RW brands. Based on what I've read and experienced with my burner, I'm going to stay away from -R media with this drive unless it's one of the recommended ones.
astonGuest
I hope that this list is not maintained... otherwise, what are the benefits of firmware upgrade ?
The problem is that I've purchased a multiformat burner, not a +R burner
I don't think it's a problem of media, because other burner give me the same dvd readable with my readers... -
Could any of you guys (Michelle, aston, indolikaa) post a media info of a DVD+R and a DVD-R with the movie on it, please?
Not that I could solve the problem, I'm just curious.
Thanks.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I can't remember where I read this but I think the new firmware is not for the DD0203 (even though it was originally listed as the 2.16 update). Has anyone else used the 2.17 update, and if so, with what results?
The remarks on firmware 2.17 may explain why:https://www.videohelp.com/dvdwriters.php?DVDnameid=96&Search=Search&list=
astonGuest
tompika -> I hope this is the info you are looking for, I get them with dvdinfo
DVD-R Bulkpaq
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID PRINCO
Format Type UDF 1.02
Volume Name MOVIE01
Application id
Implementation id AHEAD Nero
Recording Date/Time (mm/dd/yyyy) 8/31/2003 14:28:41
Format Capacity 4.36GB(4.68GB)
Free Blocks 0
Book Type DVD-R
Media Type DVD-R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 1.0x 1385KBps
Available Write Descriptor CLV 2.0x 2770KBps
Available Write Descriptor CLV 4.0x 5540KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 0B
2x Speed OPC power 0F
2x Write Strategy field 1 12 87 77 80
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 01
4x Speed OPC power 1B
4x Write Strategy field 1 0B 0F 08 08
4x Write Strategy field 2 55 09 10 0B
4x Write Strategy field 3 80 88 80 88
4x Speed OPC beta multi-pulse 05
4x Speed OPC power multi-pulse 1D
4x Write Strategy field 4 1D 86 66 85
4x Write Strategy field 5 99 BD 88 80 00 00
4x Write Strategy field 6 00 00 D0 00 00
Data area starting sector 30000h
Data area end sector 22E34Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
DVD+R Memorex
Media Information
Media code/Manufacturer ID RICOHJPNR01
Volume Name MOVIE02
Application id
Recording Date/Time (mm/dd/yyyy) 9/ 1/2003 17:57:43
Free Blocks 0
Book Type DVD+R
Media Type DVD+R
Available Write Descriptor CLV 2.4x 3324KBps
Data area end sector 22E38Fh
Number of Layers 1 -
After reading some other forums it seems like some people are having trouble getting their firmware back to 2.16. Right now 2.17 is working fine but if I am concerned that I will be stuck there for good. Once 2.18 comes out do you think I'll be able to update, or do you think Optorite will release some sort of way to get 2.17 out? I just hope it keeps working OK...
I was unable to revert back to 2.16 in Windows, but it worked fine in DOS (requires a different download).
Originally Posted by astonYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Yesterday I bought some Sony DVD-R. They are considered to be high quality disks. The Optorite burner wouldn't even recognize them. Today I exchanged them for Sony DVD+R and they work fine.
Used following media (all DVD-R & cheap from ebay!)
Burn star X2(blue)
.j...@....P.....
.....PRINCO.....
000.............
Bulkpaq X4(orange)
.j...@....P.....
.....TDKG02..000
White lable X4(white top)
.j...@....P.....
w.p..LONGTE..N 0
Originally Posted by BlizZ
Here's what I know about:
DVD-VIDEO or DVD-ROM (UDF)
With +R set booktype to DVD-ROM if you have a Ricoh-based burner -
Originally Posted by Michelle
PS: ISO setting 1.02 of courseYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Dont ask me why, probably because DVD+RW doesn't require finalization.
Ask a DVD guru.
Nero has so many options because DVD-Video format is not the only one people use.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
If I burn a DVD-R using DVD-Video and burn another one using DVD-ROM (UDF/ISO) (both with UDF 1.02) will I see any difference in DVDInfo?
I don't think so.
Why do you ask. Could you see any?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Even their programmers couldn't answer your question, I think.
Two guides of Nero
http://dvdshrink.info/nero-video.php
http://dvdshrink.info/nero-udf-iso.phpYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
The only real problem I can say these drives have are related to DVD-RW. This is not an issue for me, as my preference leans heavily towards +R/W. As for Nero, I won't be trying any DVD-Video stuff for another couple of weeks. I'm kinda hooked on DVD-Lab!
Issues with Blu Ray Players and Burned DVDs?
By mizmelzy in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Mar 2011, 04:45 -
Technika DVDFAW08 Multiregion Code and XVid Compatibility Issues
By delta925 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Dec 2009, 13:40 -
LG RH387 compatibility with other players
By Pouib in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Oct 2008, 15:40 -
The best burning speed for the most compatibility with DVD players?
By gom in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:30 -
Compatibility issues
By boing in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2007, 13:05
