Hi all,
I got a problem when burning my dvd+r in Nero. The error was popup " Burn Process failed at 2.4x speed" . how can I deal with this problem.
I got 3 incompleted dvd+r .
thanks alot.
newbie.
Results 1 to 16 of 16
That means that your hard drive/dvd/cd drive couldnt keep up pumping data to the dvd burner, so take the burn speed down to 1x, and the burn should complete..
And check to see if your burner has something called "Burn Proof", it sounds like you dont have it since your getting burn error. Solution, burn at 1x -
yes, those would be helpful toOriginally Posted by tompika
@BASDSucks
It could be lots of things.
Have you ever burned +R/W at 1xspeed on a PC recorder?
2.4x is the standard speedYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
actually, i have, on the first generation dvd burners, it had 1x burning and 2.4x.. im still thinking its the burn proof problemOriginally Posted by tompika
Edit: i didnt read fully, u said +rw, no i haven burned a + at 1x, i thought u meant a -r -
Can't really burn +R/W at 1x on a PC recorder.
DVD-R/W 1x, 2x, 4x
DVD+R/W 2.4x, 4x
IMO it sounds like a firmware that doesn't know a new and/or 4x media,
or a fragmented HDD or DMA problem.
Thats why I asked the guy to tell us more details.
Forget about 1xDVD+R recording on a PCYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Can you post what drive you have, so we can try to find a update for it.
1.51 FW should be OKOriginally Posted by batondvd
Then I suppose you know the settings ISO, Joliet,... where to put the video files, what compilation,...Originally Posted by batondvd
OK.Originally Posted by batondvd
It should be OK but could be a bad batch of discs.Originally Posted by batondvd
Last time I had an error like this my HDD was totally fragmented,
and defragmenting solved the problem.
I don't know if theres a couple of bugs still exist in Nero6 but
the latest Nero5 (5.5.10.50) and RecordNow work fine for me.
1. Is your burner properly connected?
2. Aren't you having a buffer underrun?(very visible in Nero)
3. Is your HDD defragmented before burning?
4. Have you had similar problems before or they just occured?
5. Have you tried other burning software or uninstall-install Nero again?
6. Have you tried different media?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I tried Nero 5.5.10.20, I still got the same problem
"Could not performed end session and failed to burn at 2.4x"
any burning software is good out there? give me a advices. thanks.
I lost almost 10 dvd+r for this burning software.
I am newbie in this, so please give me some suggestions.
thanks
newbie. -
I forgot to let you guys know that I could burn with dvd+rw successfully; however , I always got stuck with dvd+r b/c of " could not performe end session"
thanks
newbie. -
And you forgot to answer my and vric's questions, but we're not gonna bother you anymore.Originally Posted by batondvd
PS: writing a plus rewritable is much more easier for the burner than a write once media, and the latest Nero5 is 5.5.10.50 at the moment
Take careYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Have you tried playing these discs on a set top player . I had this problem some time ago , but it went away by itself . Could have been bad media . The reason I ask this this is because the discs I had this problem with would still play . If it was a write error it would stop playing somewhere in the movie . If it was a could not perform end of session error it would play the whole movie . Give it a try . Good luck .
Small picture in middle of screen - burned DVD in Nero Vision
By bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 17:20 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 01:20 -
Suddenly Nero SHowtime won't play DVDs that I've burned.
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 00:13 -
Burned my first divx using Nero but they are not in sync
By Taylor in forum Newbie / General discussionsReplies: 6Last Post: 3rd Sep 2007, 23:07 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 21:49
