i need help burning vcd to vcd.i tried disc juggler and it did not work.when i try to burn with nero the only file it will let me add from the vcd is the dat file is this all i need.
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
If you are trying to copy a VCD directly to another CD-R(W) all you need to do is choose "CD copy" in Nero.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
hd burning
By bigtanker198 in forum Authoring (DVD)Replies: 3Last Post: 11th Dec 2007, 07:34 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
