Elby CloneDVD has a new version out 1.2.8.4 (Aug 28th). It has a compression meter which is one feature I believe some people were looking for. Not sure if this version has optimized it's compression method any.
Whats new:
updated and integrated several old and new language files
removed all user prohibitions on Copy DVD Title
fixed IFO corruption bug (bad cell ids after single title extraction)
SHARE_READ support for image files to be written to DVD
AUDIO_TS folder generation for ISO/UDF images
fixed time measurement for the writing process (user dialog interactions won't count anymore)
made VOBSet 0 errors more user-friendly (shows file/mask missing now)
made WriteDVD 5 errors more user-friendly
extended automated main movie selection to all available angles
quality indicator (compress-o-meter) on title selection page
fixed: DVDManager 1 for most titles
changed time format to always show the 'minutes' component
set tcengine to "below normal" thread priority
updated ElbyCDIO driver
Results 1 to 20 of 20
ive never tried that program, i mainly use dvd x copy, but i will give that new version a try.
If you use this program for the first time, you'll need another program called AnyDVD if you plan on copying a copyrighted movie.
i kinda figured that out when i couldnt copyOriginally Posted by Vanderlow
did that, im burning my test dvd on a -rw, its almost doneOriginally Posted by Vanderlow
Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
i cant get to the site!!! this is getting irratating!!!
could it be because im trying to access it from hawaii???
Elby has been having some hosting issues lately, actually.
http://www.elby.de
Is the place to nab CloneDVD.
And...
http://www.slysoft.com
Is the place to get AnyDVD.
- Gurm -
elby.de and elby.ch does not work here(my dns wont resolve them).
I must use the IP
http://213.130.59.30/en/products/clone_dvd/index.html -
The above posted 213. url works, but it should be the same as this actual url which is the one I use and works for me.
http://www.elby.ch/en/products/clone_dvd/index.html -
You only need ANYDVD if you want to make a copy from the DVD-ROm drive.if you do not have ANYDVD you can just rip the DVD with smartripper. Also DVDregionfree works just like ANYDVD
I believe someone post that AnyDVD increased the ripping speed of one of their other DVD to DVDr programs that has decryption in it;
maybe since it does it "on the fly". But other posters make a good point there's other freebies out there....experiment! -
Am currently testing v1.1.7.1 with mixed results. Copies from single layered discs came out fine but dual layered discs experienced a dropped frame or two. Maybe it's my processor and/or the ammount of RAM. I'll give the latest version a try. My tool of choice also is DVDCopy Xpress.
I read someone's opinion on the 1.1.7.1 ver. that it does very well till you get to the 70% level, then you may prefer other applications.
Clonedvd 2 question...
By ironmanDD in forum DVD RippingReplies: 1Last Post: 21st Jan 2011, 00:41 -
Do i have to get clonedvd?
By blaqlion22 in forum DVD RippingReplies: 3Last Post: 30th Jan 2008, 11:28 -
CloneDVD or Shrink?? Which is Better?
By Jonathan in forum DVD RippingReplies: 15Last Post: 22nd Dec 2007, 21:52 -
Does CloneDVD compress AUDIO too?
By Serpeant in forum DVD RippingReplies: 3Last Post: 6th Aug 2007, 11:23 -
CloneDVD to rip instead of AnyDVD. Why?
By rkr1958 in forum DVD RippingReplies: 7Last Post: 4th May 2007, 22:44
