I use movie factory 2 which is great 4 me coz its easy 2 use.
I have a movie in 2 parts which mf2 nicely makes a dvd which I can play on my player,the only thing im missing is a title page.
I know mf2 has 1 but its smallest option has 2 boxes and I just want 1 or a text link which will lead to the movie starting so I can put a background of my own and just have the text link l8r ill try spliting the movie so i can have chapter but 1 step at a time.
So after what I have said can someone tell me what I can use instead of mf2 (it needs to b easy like mf2).
cheers
You can create something that resembles a title page in MF2 by inserting a slideshow of one image as the first video clip and ticking the 'First clip as first play video' option.
When the DVD starts it will show the slide first for what ever time interval you set and then on time-out will launch into the first menu or first video depending on how you set it up.
While the slide is showing you can still press the player 'next' or 'menu' buttons to move forward during playback.
advice on specs needed for new pc
By angryassdrummer in forum ComputerReplies: 4Last Post: 21st Jun 2011, 02:31 -
Media PC Advice Needed Please
By jaffacaique in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2009, 22:06 -
New Case Needed....Advice?
By ron spencer in forum ComputerReplies: 4Last Post: 2nd Feb 2009, 18:44 -
TSmuxer Advice needed
By zenzen1 in forum Blu-ray RippingReplies: 2Last Post: 10th Nov 2008, 09:12 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
