Hi all, newbie here.
Firstly, I am in the UK so am using the 50hz PAL system.
I am trying to capture from some old VHS tapes and create DVD's of them using my Leadtek Winfast A350TDH graphics card (MyVIVI edition) which has video capture capability. I am using Ulead Moviefactory2 SE that came with the card.
My original problem was fast moving images flickering badlywhen played back on a standalone DVD player. Thanks to the help in these forums, I think I've sorted this one out. It was down to the software defaulting to progressive scan output. Having set it to "Field order B" the video seems much smoother.
My problem now is that bright scenes are flickering quite badly. If I capture the video through my DV camcorder onto DV tape, then do a DV capture onto the PC and then to DVD, the flickering is not there and everything is fine. iIn both cases I am capturing directly to MPEG2.
Any help / ideas / suggestions gratefully accepted.
Results 1 to 1 of 1
TV makes a buzzing sound when scenes are bright.
By Denvers Dawgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Nov 2011, 12:32 -
= bright and dark
By beetlespin in forum EditingReplies: 6Last Post: 16th Aug 2010, 19:38 -
New LCD monitor, seems awfully bright!! help!
By sdsumike619 in forum EditingReplies: 20Last Post: 28th Oct 2008, 14:13 -
Bright red, blue?? help...
By waefwaeefwaefw in forum EditingReplies: 3Last Post: 12th Sep 2008, 21:31 -
Problems encoding low-contrast bright scenes
By padeen in forum Video ConversionReplies: 5Last Post: 26th Aug 2008, 10:21
