Hello,
I am trying to convert a 24 GB Motion JPEG movie wich I recorded with my miroDC30 into DVD format. The process starts and after about 1 GB of conversion it stops and I get the error message below. I am using a registered version ffmpegX 0.0.7c, today I tried to download version 0.0.7d but after the download finishes the dmg-file shows always version 0.0.7c.
However, unfortunately I have know clue why ffmpegX does not finish the conversion though it does start as usual.
I am using the hi-bitrate DVD (Pal) preset in ffmpegX and chose to process as VIDEO_TS, no elementary streams.
Any hints are very much appreciated.
Best regards
Alexander
Aug 20 13:27:36 Alex-Computer crashdump: Crash report written to: /Users/al/Library/Logs/CrashReporter/ffmpeg.crash.log
Aug 20 13:27:41 Alex-Computer crashdump: Crash report written to: /Users/al/Library/Logs/CrashReporter/???.crash.log
ffmpeg.crash.log
Date/Time: 2003-08-20 13:27:36 +0200
OS Version: 10.2.6 (Build 6L60)
Host: Alex-Computer.local.
Command: ffmpeg
PID: 446
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x003e1000
Thread 0 Crashed:
#0 0x000307d8 in 0x307d8
#1 0x0003241c in 0x3241c
#2 0x00025958 in 0x25958
#3 0x000032bc in 0x32bc
#4 0x00002194 in 0x2194
#5 0x00001b74 in 0x1b74
#6 0x000019f4 in 0x19f4
PPC Thread State:
srr0: 0x000307d8 srr1: 0x0200f030 vrsave: 0x00000000
xer: 0x00000000 lr: 0x000308b0 ctr: 0x0000001f mq: 0x00000000
r0: 0x00000000 r1: 0xbffdf070 r2: 0x000000ff r3: 0x00000000
r4: 0x00000001 r5: 0x000000f1 r6: 0x003e0e7a r7: 0x000000a2
r8: 0xbffdf163 r9: 0x00000183 r10: 0x00000c18 r11: 0x00000000
r12: 0x00000000 r13: 0x001db720 r14: 0x00000002 r15: 0x001db740
r16: 0x00000001 r17: 0x00000000 r18: 0x0014e13c r19: 0x00000000
r20: 0x00000000 r21: 0xbffdf540 r22: 0xbffdf710 r23: 0x00032414
r24: 0xbffdf0e0 r25: 0x001db8f0 r26: 0x00000c18 r27: 0x000007f8
r28: 0xbffdf0c0 r29: 0x000000a2 r30: 0x001db8f4 r31: 0x00000001
???.crash.log
Date/Time: 2003-08-20 13:27:41 +0200
Command: Unknown
PID: 453
Codes: KERN_INVALID_ADDRESS (0x0001) at 0xc0000000
Thread 0 Crashed:
#0 0x000a9474 in 0xa9474
#1 0x00003264 in 0x3264
PPC Thread State:
srr0: 0x000a9474 srr1: 0x0200d030 vrsave: 0x00000000
xer: 0x20000000 lr: 0x000259a8 ctr: 0x000a9454 mq: 0x00000000
r0: 0x00000004 r1: 0xbffdf540 r2: 0x0000f7a2 r3: 0x003a7632
r4: 0xbffdf9d0 r5: 0xbffff9f0 r6: 0x00387000 r7: 0x000000a2
r8: 0x0000f700 r9: 0x000000f7 r10: 0xc0000000 r11: 0x00005ce7
r12: 0x00000050 r13: 0x001d8150 r14: 0x00000002 r15: 0x001d9740
r16: 0x00000001 r17: 0x00000000 r18: 0x001d9780 r19: 0x00000001
r20: 0x00000000 r21: 0x00000000 r22: 0x00000000 r23: 0x001d7430
r24: 0x00387000 r25: 0x0002c000 r26: 0x00000000 r27: 0x00000000
r28: 0x001d9780 r29: 0x001d97c0 r30: 0xbffff590 r31: 0x001d8548
AlexGuest
AlexGuest
I tried the conversion again today, as explained above ffmpegX starts the job as it should but crashes after a while. At the stage it crashes I have always a *.m2v file about 1 to 1,5 GB in size and a *.mp2 file with 0K.
Below is todays output from the terminal as well as the latest crash logs.
Again thanks for any hints.
Alexander
Last login: Sat Aug 30 10:18:12 on ttyp1
pbpaste | sh
Welcome to Darwin!
[Alex-Computer:~] al% pbpaste | sh
Encoding started on Sat Aug 30 10:18:13 CEST 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Input #0, mov, from '/Volumes/fette_beute/Noorderlingen':
Stream #0.0: Video: mjpeg, 720x576, 25.00 fps, 800 kb/s
Stream #0.1: Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 720x576, 25.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
Error while decoding stream #0.0B time=1204.2 bitrate=124417.4kbits/s
Error while decoding stream #0.0B time=2022.2 bitrate=124417.4kbits/s
Error while decoding stream #0.0B time=2231.9 bitrate=124417.4kbits/s
RESET 0 14 err:0ize=37936979kB time=2497.9 bitrate=124417.4kbits/s
CODECID 31 31 sowt
Output #0, mp2, to '/movie/Noorderlingen.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.1 -> #0.0
sh: line 1: 621 Segmentation fault /Volumes/speisekammer/Applications_Mac_OS_X/ffmpegX_0.0.7/ffmpegX.app//Contents/Resources/ffmpeg -i /Volumes/fette_beute/Noorderlingen -y -vn -f mp2 -acodec mp2 -ab 224 -ar 48000 -ac 2 -map 1.1:0.0 /movie/Noorderlingen.mp2
ffmpegX.crash.log
Date/Time: 2003-08-30 16:08:46 +0200
Command: ffmpeg
PID: 614
Thread 0 Crashed:
PPC Thread State:
???.crash.log
Date/Time: 2003-08-30 16:08:51 +0200
Command: Unknown
PID: 621
Thread 0 Crashed:
PPC Thread State:
r12: 0x00000050 r13: 0x001d8150 r14: 0x00000002 r15: 0x001d9750
r16: 0x00000001 r17: 0x00000000 r18: 0x001d9790 r19: 0x00000001
r28: 0x001d9790 r29: 0x001d97d0 r30: 0xbffff590 r31: 0x001d8548
AlexGuest
Hello,
I added the extension .mov to the file and tried with and without capital letter at the beginning of Noorderlingen.mov and noorderlingen.mov. Now I do get a mencoder crash as soon as I press the open butten in ffmpegX:
Date/Time: 2003-08-31 11:45:31 +0200
Command: mencoder
PID: 441
Exception: EXC_BREAKPOINT (0x0006)
Code[0]: 0x00000001Code[1]: 0x8fe01280
Thread 0 Crashed:
#0 0x8fe01280 in halt
#1 0x8fe0329c in load_library_image
#2 0x8fe06134 in load_images_libraries
#3 0x8fe026e8 in load_executable_image
#4 0x8fe01410 in _dyld_init
PPC Thread State:
srr0: 0x8fe01280 srr1: 0x0002d030 vrsave: 0x00000000
xer: 0x20000000 lr: 0x8fe0a064 ctr: 0x8fe28f78 mq: 0x00000000
r0: 0x00000004 r1: 0xbffffb50 r2: 0x796c6962 r3: 0x00000075
r4: 0x00000000 r5: 0x00000075 r6: 0x0000290a r7: 0x726e6f20
r8: 0x66696c65 r9: 0x00000000 r10: 0xbffff8cb r11: 0x00000026
r12: 0x8fe71a9d r13: 0x00000000 r14: 0x00001d50 r15: 0x00000000
r16: 0xbffffdf4 r17: 0x00000001 r18: 0x0000158c r19: 0x00001878
r20: 0x00000001 r21: 0x00000000 r22: 0x00000000 r23: 0x00000000
r24: 0x8fe4b3cc r25: 0x00000002 r26: 0x00000002 r27: 0x00000000
r28: 0x0000174c r29: 0x00000000 r30: 0x8fe484d8 r31: 0x8fe09ecc
Date/Time: 2003-08-31 11:46:33 +0200
Command: mencoder
PID: 447
Thread 0 Crashed:
PPC Thread State:
srr0: 0x8fe01280 srr1: 0x0002f030 vrsave: 0x00000000
AlexGuest
Well, after the crash of mencoder in the console ffmpegX did show the right path in the window. I just quit the console and started the conversion, which is currently still running, although the terminal does not show the usual output (the line with the number of frames is missing, see terminal output below). However, currently are about 550 MB converted and it is still running, I wait and see what is happening when we are in the 1 GB range again. I might not be able to leave it converting until it finishes today since my 450 MHz G4 might be to slow. It resides in my sleeping room and is to noisy to leave it running through the night. I let it start again tomorrow early morning though. But today I will see how far it goes.
Thanks for the hint anyway.
Alexander
Terminal output does not show the typical line with frame#
Last login: Sun Aug 31 11:54:42 on ttyp1
pbpaste | sh
Welcome to Darwin!
Encoding started on Sun Aug 31 11:54:43 CEST 2003
AlexGuest
Just to show you what is happening, I post the concole log and the mencoder crash log again. The console crashes exactly each time I do this:
I press the open button and the file dialogue appears. I navigate to the volume where the file is located. As soon as I select the the renamed file noorderlinge.mov and press choose I do get the console error.
However, I will now try to start the conversion again and let you know what happens tonight.
Regards
Alexander
console output:
2003-09-01 07:01:26.171 pbs[353] CFLog (0):
CFPropertyListCreateFromXMLData(): plist parse failed; the data is not proper UTF-8. The file name for this data could be:
<plist resource in resource fork> of bundle: /Applications/Utilities/ATI Utilities/ATI Monitor
The parser will retry as in 10.1, but the problem should be corrected in the plist.
Sep 1 07:02:06 Alex-Computer crashdump: Crash report written to: /Users/al/Library/Logs/CrashReporter/mencoder.crash.log
Sep 1 07:03:24 Alexander-Hopsteins-Computer crashdump: Crash report written to: /Users/al/Library/Logs/CrashReporter/mencoder.crash.log
Sep 1 07:04:00 Alex-Computer crashdump: Crash report written to: /Users/al/Library/Logs/CrashReporter/mencoder.crash.log
Sep 1 07:04:38 Alex-Computer automount[410]: automount version 26
mencoder.crash.log
Date/Time: 2003-09-01 07:03:24 +0200
Command: mencoder
PID: 377
Thread 0 Crashed:
PPC Thread State:
Date/Time: 2003-09-01 07:04:00 +0200
Command: mencoder
PID: 382
Thread 0 Crashed:
PPC Thread State:
AlexGuest
With ffmpegX 0.0.8 the conversion is now working without any errors but is pretty slow although I upgraded my original G4/450 Sawtooth with a Sonnet 800 MHz. Might be due to the large original MJPEG file with 23 GB.
Best regards
Alexander
Encoding started on Wed Sep 3 06:20:54 CEST 2003
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm PAL
INFO: [mpeg2enc] Encoding MPEG-2 video to /movie/noorderlingen.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [mpeg2enc] GOP min length too small to permit scene-change on GOP boundary 24
99.49% done, estimate finish Thu Sep 4 09:22:00 2003
99.81% done, estimate finish Thu Sep 4 09:21:59 2003
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4096
Path table size(bytes): 42
Max brk space used 0
1557968 extents written (3042 Mb)
Encoding completed on Thu Sep 4 09:22:00 CEST 2003
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 06:12 -
4 1GB VOBs - how to make a dvd?
By texas1 in forum Authoring (DVD)Replies: 1Last Post: 15th Nov 2007, 22:44 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38 -
ffmpegX crash when converting to DVD
By granoli in forum ffmpegX general discussionReplies: 0Last Post: 2nd Jul 2007, 19:39 -
Want to make 1GB ASF smaller
By jabroni in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2007, 00:01
