i loaded 4 svcd's into hard drve,put them in folder,used svcd2dvd+,but it keeps coming up *no bin files.
i am a real beginner at this(as you can no doubt tell),but can anyone tell me what to do now.
are your files u rip bin files ? have a look.if they are not open svcd2dvd and click on an mpg setting try that.
thanx for your reply.still doesn't work.files in movies are.
mpeg video/audeo stream.
IMG file.
CUE file.
SUB file.
i tried your suggestion of using the mpg settings,came back not valid mpeg files.
hope you can help. -
can you screenshot your error messages and the contents of the folder you are having issues with.
sorry i cant seem to get screenshot. i can only type the information to you
hope this helps.
(s)vcd2dvdmpg status.
x no *.bin files in :c:new folder.thisis what i get when i try to load files in svcd2dvdmpg.
the files are as follows.hollywood homicide1.cd1
IMG FILE
811,802 KB
hollywood homicide 1.cd1
MPEG video/audio stream
1 KB
hollywood homicide 1.cd1 cue
CUE FILE
1 KB
hollywood homicide 1.cd1 sub
SUB File
33,106 KB
and the same for the rest of the discs,all are IMG. MPEG video/audio stream. CUE File. SUB File per disc.
but keep getting the same message..when i try to open folder in programme..no*.bin files.
i just dont know what bin files are or how to change them into bin files.
sorry for being a pain,but as i said earlier i am a complete newbie,
many thanx for your patience and help.. -
cajonGuest
Yours is not a bin/cue its a image file for alcohol 120% or clone cd, you need *.cue and *.bin (you can use an ISO buster program to fix that)
Hey,
If i read it right you got files with the following extentions: .cd1, .cd1, .cd1 which indeed aren't .bin files. You need to have a file named something.bin or something.mpgGreatings,
Yf
