  1. I went to change the region setting on my NEC DVD+RW ND-1100A that is in my new Dimension 8300 computer only to find that i had only ONE change left!
    Im in region 4 now (Australia) and desperately need to change the region to region 1 for a bit (as i bought American region DVD's from Amazon and want to copy them onto my computer and watch them as VOB files) and then change it back to region 4.
    Can someone help me do this even though ive somehow only got 1 change left in my NEW DVD burner?! Id love some links to software wich will override this think on my NEC DVD+RW ND-1100A.
    THANKS!
  2. http://etna.rpc1.org/nec/index.html
    Flashing is dangeruos!
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Use DVD Region Free (makes all dvd drives multi-region)
    download the demo from www.dvdidle.com (will cost $40 for the full version)[/url][/code]
