Results 1 to 16 of 16
  1. Every question i post here, i never get a reply.
    so is there anyone who's kind enough to help?
    it would be a big help if anyone can put like 1 min. to reply my question if anyone knows it.
    recent questions posted:
    Aug 24, 2003 02:12
    how to extract audios by chapters?
    Aug 24, 2003 01:57
    Keeping original menus after Demuxing...
    i would appreciate it if i can get some help.
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Aug 24, 2003 02:12
    Not possible as far as I know. The best thing would be to convert your audio to a WAV audio file (if it isn't already a WAV) and edit out the part you want.
    Aug 24, 2003 01:57
    Not enough detail here. What are you trying to do?
    I've never tried to extract MENU designs myself but I know it is possible but if you are trying to do any type of converion such as PAL to NTSC or vice versa then forget it. It is not even remotely worth the effert.
    - John "FulciLives" Coleman
  3. In almost all cases the reasons why you don't get an answer (these are generic, not necessarily directed at you) are the following:
    1. Your question isn't clear or you didn't provide enough detail on what you want to do (e.g., "I can't get my VCD to work. Help!")
    2. Your post is hard to read BECAUSE YOU TYPED IT IN ALL CAPS or you used irritating abbreviations/spelling
    3. You were rude and/or demanding in your request
    4. You haven't waited long enough
    Number "1" is the biggie. If I can't get a good handle what you are actually trying to do after a quick read of your post, I will ignore it. I assume most other people do the same.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. Member wulf109's Avatar
    Jul 2002
    Rip by chapters then demultiplex the audio stream.
  5. Try searching the board first to see if its been discussed before. you ask. I don't like to answer the same question every day.
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Perhaps it was because the two topics you mentioned have problems.
    One is in the wrong forum and the other can be considered warez. Perhpas people didn't want to assist you in a warez discussion.
    What about your first post? You got two replies and seemed to get an answer. Did you forget about that one??
  7. Always use pictures. They help with errors, i.e.:
    If your question was "Why doesn't TMPGEnc support my sound file?", then we couldn't answer you. But if you included a picture like so:
    Then we would tell you TMPGEnc doesn't support AC3 audio.
    May 2003
    Pal Realm
    Maybe Vitualis' post (and additions by others in this thread) should be a sticky on every forum?
    Nice & clear and who knows? might help. :c)
  9. Member adam's Avatar
    Sep 2000
    Yes you can extract audio by chapter in DVD Decryptor, and probably any other ripper that supports stream processing as well. In DVD Decryptor set it to IFO mode and uncheck all but the chapters you want. Then go to stream processing and enable stream processing. Uncheck all but the audio stream you want, right click on it and hit, "set selected-demux." Then rip as normal and it will spit out the AC3 tracks for just the selected chapters.
    As for your second question, I have no idea what you are asking.
  10. Member SaSi's Avatar
    Jan 2003
    Hellas
    The best program to use for demuxing and extracting anything out of the DVD structure by chapter or whatever, is - it think - SmartRipper. I agree that DVDDecrypter can do it also, since people say so, but I think it is a bit too complicated or restrictred compared to SmartRipper. (But always use DVDDecrypter to rip the DVD).
    As for the second question, you really are unclear.
    If however what you are asking is:
    I want to demux video and audio streams from a DVD, re-compress some of them to make them shorter (so that they fit on a DVD5) and then find a way to put everything back together so that the original structure (menus etc) remains intact.
    Then, your best bet is to use DVDShrink. Version 3 beta 5 has solved all the original version's limitations and bad picture quality when compression was high.
    And, be patient.
    The more I learn, the more I come to realize how little it is I know.
  11. Please remember that no one is paid to help you, this is not tech support. So stop whining.
    Also remember that no one, at least so far as I know, has a crystal ball here. While your first question was clear enough, and simple to do, your second question makes no sense. There are detailed guides on keeping menu structure for recompressed DVD's, have you read them?
    Read the FAQ, read the guides, and do a forum search. I personally rarely answer questions from individuals when it is obvious that these have not been done.
  12. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    I have a crystal ball....
    And the answer is still....
    No I will not help
    Ok, really I have no idea, but just wanted to be a jerk.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  13. Originally Posted by The village idiot
    Mission accomplished
  14. One of the above posters WANTED to be a jerk and the other one ACCOMPLISHED it. We won't call any names, Craig.
    Just JK.
  15. Of course not....
    O Kewl is a jerk
  16. Originally Posted by g_shocker182
    Of course not....
    O Kewl is a jerk
    Nobody has EVER insulted me that much!!!
    It isn't "O Kewl is a jerk" but.............."0 (zero) Kewl is a jerk"
