I was wondering if anyone here has done a lightsaber effect in a home movie. I need to do something similar for my media tech class, and some pointers would be very helpful. If someone could please link me to a tutorial, I'd appreciate it.
Results 1 to 19 of 19
I've done em' before. Check out http://www.alamdv.com It's the simplest way to add them.
Thanks for the links, looks like there should be some good info there.
I forgot to mention, I'm working with Adobe Premiere, Adobe After Effects, and Adobe Photoshop. A method that I have seen with the software I have requires you to paint the "Lightsaber" on each individual frame, which, depending on the length of our movie, this might take a really long time! Is this really required (painting it on each frame)? Or is there a different way to go about this?
Thanks -
With Alamdv and After Effects you can tween, but you still will have to manually check each frame to make sure it's correct. Welcome to the world of SFX and endless hours in front of a computer editting frame by frame
another software you might check (and a good way to get it cheap):
ParticleIllusion from Wondertouch can do stuff like this. Pretty easy to use once you follow the tutorials, and it's got a good community running forums and putting out new emitter libraries for it.
I think (although I'd have to find the reference to say for sure) that AlamDV started as a spinoff from ParticleIllusion.
The nice thing is, Pillusion 2.0 SE is included free with the August 2003 issue of Digit Magazine from the UK - you can find it at Barnes & Noble or MicroCenter. $14 for a piece of software that their website sells for $99... not bad. And usually it's a cheaper deal to upgrade to the current version, if you upgrade from a Digit copy.
check it out, they have a demo online.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Looks like thats what I'll have to do.
Thanks a lot! -
Originally Posted by tgpo
http://fxhome.com/Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
Originally Posted by Greenspock
I saw a premier or after effects plug in that does just this a while back, but I can't remember what it's called. It also did machine gun effects and stuff too. It was very cool!
"Terminated!" :firing: -
This sort of strays from my topic... but does anyone know how to "render" or export a movie in Premiere? The timeline has some "virtual clips" in it as well (i heard this makes a difference?). I'm pretty new to premiere, so if someone could help me out, I'd appreciate it.
Thanks -
I'm trying to remember back to it......Try clicking on the timeline and hitting enter.
Enter does the preview (helpful key to know, thanks). Reason I asked is because everytime I rendered, my movie wouldn't move. I tried a different codec and it worked fine, so I guess I picked a bad codec to encode with.
OH!! I thought you just wanted to know how to render the video, which the enter key does.
I'm not "down" with the lingo yet, sorry for the confusion. What I wanted was to export. Any idea how to export starting at a certain frame? I've tried setting "in and out" points but the video always exports as the entire timeline
Right above the timeline you should see a triangle on the far left. You can click and drag it to where you want it to start, same for the end. I also think you can double click to get one....I'm having to remember from over a year ago
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
"Unsharp Mask" effect to a whole MP4 movie
By majortom67 in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2010, 12:13 -
how to create "thinking" effect(when someones voice plays in head
By bojadada in forum AudioReplies: 3Last Post: 20th Dec 2008, 12:23 -
Eliminating "Tearing" effect in 2D games with Vsync & Triple
By retroborg in forum ComputerReplies: 1Last Post: 17th Dec 2007, 10:50 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
