HOW do I remove the annoying white line in Nero 5.5? I got the items text removed with the invisible font but the white line persist and it really screws up the nice bitmap picture I had in mind...please anyone know?
/Jonas
jonas.sandman@home.se
you cannot, its hell annoying. nero menu editor sux very badly. its bloody hopeless, anyway try this (you probably already have). go into all the text boxes, and hold ALT and press 0160 on the num pad. it should look like your pressed space bar, but it is a character. that will get rid of some shit.
under nero 5540
u can disable this line
upgrade for that application , it will serve your request
yes try nero 5.5.4 it does have a check box to remove the header line.. granted nero is not a good author program but by removing the header line now my little menues look a heck of alot better
Tool for move in-out main movie from blu-ray files system. ( has menu )
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Mar 2011, 05:03 -
Need a simple menu system after combining several small DVDs plese
By scp1973 in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2008, 11:14 -
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 10:58 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26
