I have encoded nearly +60 Movies in Tmpegenc and this is the first time it happens this to me. THe audio at first seems fine but later it is almost 5 secs faster.
I think is because of the AVI fps, that is 25, and the VCD is Ntsc 29,97 if i am not wrong. I used "Audio Edit" and 400% of volume. Is this the true problem?
What can i do! Anything instead Converting to PAL!
Results 1 to 9 of 9
Originally Posted by shin_zer
That is exactly the problem. Try using the AWESOME tool BeSweet, a freeware program that allows you to change your audio framerate to match your videos. Also when you set your volume to 400%, are you normalizing it? You shouldn't set it to anything above 100% unless you normalize, because you can clip the audio's wave and distort the sound.
Also I personally would never select the 'DO NOT FRAME RATE CONVERSION' this would cause your video to stay at 25fps. Then FulciLives says to convert the audio's frame rate to 23.976. As you can see 25 and 23.976 = audio sync problems. You could untick that option then use BeSweet to fix the audio then both would be at 23.976 (if the video is progressive like FulciLives said).
I would and I know you said you didn't want to, if your player can, leave it at PAL. 99% of all new players play PAL and NTSC, and then you won't have these problems. -
Originally Posted by roach1976
- John "FulciLives" Coleman
P.S.
For more info on doing PAL to NTSC conversions please see the following two links:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=
Good Luck
*** EDIT ***
Please note that everything I have said is more or less assuming a PROGRESSIVE PAL source. If you have an interlaced PAL source then there is another way to do the conversion that works better ... see the links above for more details."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
You could be right, but I was going off TMPGEnc's Help File that came with the program.....
'Do not convert frame rate'
Enable this to disable frame rate conversion. This is normally a bad thing because it will cause a film's audio and video to become out of sync if the source frame rate different from the selected output frame rate.
Normally, this is not enabled. -
Let me explain ... FILM is 24fps so PROGRESSIVE NTSC is about the same (23.976fps) but PAL is 25fps so the film source (24fps) is simply "sped" upto 25fps for PAL so to convert it back to FILM/NTSC you have to slow it down to 23.976fps and this is what happens in TMPGEnc when you check the DO NOT FRAME RATE CONVERSION option. If you don't check that option then TMPGEnc will drop and/or blend frames to achieve the 23.976fps frame rate RATHER THAN just slowing it down from 25fps to 23.976fps
The way TMPGEnc does it the original PAL audio will match the new NTSC video but you get choppy video playback. The method I described gives you a properly converted PAL to NTSC video but you must then slow down the audio (with BeSweet) since the NTSC is now LONGER than the original PAL since we simply changed the frame rate from 25fps to 23.976fps
Hopefully that makes more sense now
I think I understand what you're saying...
If I don't select that option, then say TMPGEnc will skip say the 25th frame every second and leave that out of the final video. You'll have a 24fps (23.976) video but it will still run for the same time and there will be audio problems because when multiplexed it becomes choppy because it's a different frame rate. But this option can't be selected because BeSweet doesn't drop frames in the audio, it slows it down. Then you'll have sync problems.
If I do select that option, then the first second of the video will have the first 24fps, then the 25th frame will be the first frame in the next second and this will continue throughout the video stream, but the movie will now run slightly (4%) longer than previously but the video's length now runs for the correct time as originally intended. This method then matches BeSweet's method and then everything is in sync and running for the correct length.
Is this right? -
You got it
Woohoo. Thanks for explaining that, and yet through the forums I learn another thing!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 14:39 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51
