i have been using dvd x copy xpress version 2.0.1 and have had no problems. I have tried the newer versions and it would go through the whole process but it would no play in ether computer or any dvd player. i have read that the new versions are able to copy eposide dvd sets? I am trying to burn the family guy dvd set?? please if you know how to fix the xpress problem ???
I had problems with XCopy Xpress burning too. My solution was to let it rip the movie- when it tells you to insert a blank DVD, open the Task Manager and 'End Task' for XCopy. That will close Xpress without deleting the ripped files.
The you just use any burn program (Nero, Instant Copy, etc) to burn the DVD.
The new versions do give you an option to copy the entire disk instead od just the movie, so for episode DVD sets just select that option.
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23 -
old copy of dvd xcopy xpress
By wisconsin girl in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 17:19
i have been using
