Hey guys,
I bought a sony dru-510a and am running it on winxp and and having some problems. I'm using smartripper and when I try and rip something I don't get more than a 0.4x speed. Also, my nero burning rom doesn't recognize the burner as a recorder. It had no problems recognizing the cd-rw that used to be in the same bay that the dvd burner is in now.
I read through all the forums and tried to troubleshoot it as much as i could. I installed force aspi and have aspi 4.60 on my xp. Before I ran force I was getting a max rip rate of .01x, so it seems to have gone up a little bit, but not quite sure why it's only at .04x and why my nero isn't recognizing it.
Any help would be greatly appreciated. Thanks!
r.
I believe it's 5.5.9.x
As far as the firmware goes, I don't know what that is or how to upgrade it. I read that it's necessary for certain burners but I didn't think I needed to upgrade the firmware since my burner was a 4x speed burner.
Please let me know where/how I can upgrade the firmware and if I really do need to. Thanks!
r. -
never mind i found a thread that had my answer.
i'll install the firmware and see if it helps.
thanks!
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
