Hello
I have a standalone dvd player (samsung dvd 811) that doesn't play my dvd-r's without pixels or jumps...
next to my 29" tv I have a htpc connected to the tv via a ati radeon 7000 tv-out, this htpc does not have a monitor connected to it, I use it for divxplayback.
I have tried my dvd-r's in the htpc and they play perfectly without pixels and it doesn't jump...
The problem is that the tv-out quality isn't as good as the quality through my standalone dvd-player, so I thought: either I buy a new standalone dvd-player that better can handle dvd-r's OR I buy a mpeg-card (like the xCard) and use the htpc as a dvd-player?
now to my questions:
1.
how is the dvd-playback quality with xcard compared to the quality I get with a standalone dvd-player (with standalone dvd-player I mean one that costs about 300$)
2.
How would I connect the xcard to the tv? via scart? and how does the playback work? I know I can't use windows when using the xcard, does this mean that I have to switch between the tv-out and the xcard weither I like to be in windows and then switch to xcard when I wanna watch a dvd?
or does the xcard automaticly take over when I load a dvd in the dvd-rom at startup? how does this work?
3.
My currently soundcard is a !live 5.1 which I have connected to my reciever, I'm sending digital signal to the reciever which let's the reciever encode the signal to DD..
does the xcard also do audio? Do I have to connect the xcard to my reciever aswell or can I simply use my soundcard for that and disable the xcard's audio?
I would appriciate any answeres I can get.
/Kim
i j ust got my xcard this week. my standalone dvd player(jvc) is now sitting on the shelf un plugged. i love it!!!!!
it plays independently from the computer i watch movies and work on the computer at the same time. my set up is to a 52 inch sony high def tv. and a sony sorround system. no problem.
i can play movies over my network as well.i don't even have to convert my mpegs or avi's i say the card is a good buy
General Computer Questions
By mccoady in forum ComputerReplies: 9Last Post: 28th May 2011, 22:44 -
few general questions about dvd converting
By kobi_af in forum Newbie / General discussionsReplies: 11Last Post: 25th Nov 2009, 16:19 -
General PC video card questions
By GLE3 in forum ComputerReplies: 7Last Post: 16th Mar 2009, 13:47 -
MPC HC, some general setting questions
By THX-UltraII in forum Software PlayingReplies: 7Last Post: 25th Nov 2008, 09:13 -
some general MPC settings questions
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 07:28
