When I try to convert my AVI files to Mpeg 2 to be burned onto a DVD I loose the aspect ratio of my 16:9 movies. I have tried TMPGEnc using 16:9 in all available aspect ratio choices but it still stretches my movies. Is there another program to convert my movies or is there a way to add black bars to the top and bottom of my movie?
what bugster said will work, and is probably the easiest way to do it.
AVISynth can resize and add borders, more complicated, but faster in my experience.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Source Aspect Ratio: 1:1 (VGA)
Output Aspect Ratio: 16:9
Video Arrange Method: Full screen (preserve aspect ratio)
Three other things:
1) Anamorphic DVDs are ONLY supported at 720x480/576. If you are using a different resolution you HAVE to letterbox the video.
2) You MOST author with a program that can insert the 16:9 flag in the IFO.
3) If you divx/avi was not correctly encoded (and most are not) the aspect ratio can be off resulting in some small letter boxing. However if the divx was encoded with black bars (ie. letterboxing) as PART OF the divx file, TMPGenc will treat that as video and really screwup the aspect ratio of the video. If so you'll need to crop out the black bars prior to encode (either from within TMPGenc or frameserve with avisynth/Vdub)
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 02:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 00:40 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 10:08 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 10:02 -
avi conversion problems
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 04:27
