I am a new user of SVCD2DVD and have a problem. I start with three SVCD MPG files totaling 1.78GB. SVCD2DVD processes these files and creates new files totaling 1.71GB. When the DVD folder is created the VOBs total 2.7 GB. This is a gain of almost a full GB. Am I doing something wrong or is this to be expected?
No its not to be expected.
you should have the 3 _DVD.mpgs as stated but your VOBs should also be around this size.
You are only running it once? With only mpgs in the folder? And no VIDEO_TS folder already there?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thank you for your prompt response.
I have rerun SVCD2DVD with the same result. The output DVD VTS is almost 1GB larger than the input. After scanning the output DVD I found that the input is duplicated but the duplication starts with the second input MPG. That's why the output is not twice as big as the input.
I should point out that I am processing two input SVCD MPG sets. In the author step I create two VTSs and separate the input MPGs. Both sets of input files are duplicated in the VTSs starting with the second input MPG. The first input MPG is not duplicated.
My input folder contains only the input SVCD MPGs and the _DVDs created by SVCD2DVD.
Any insight you may provide will be appreciated. -
Guest
This could be from the audio getting uncompressed.
SVCD audio is very compressed (usually). I don't think consumer level DVD authoring tools offer any audio compression, so you can see a large (up to 600MB I think) increase in size.
Hope that helps.
Greg -
Guest
OK, I think I have identified either an incompatibility or a bug in SVCD2DVD.
I have processed the original SVCD MPGs four(4) time using various forms of input with the same files. The result is the same each time. The second and third input MPGs are duplicated in the DVD VTS output. The input SVCD MPGs are direct output from DVDx 2.2.
Thinking there might be some incompatibility with direct DVDx 2.2 SVCD output I decided to rip the MPGs from CD. I ripped all three MPGs using ISOBuster. Files 1 and 3 were exactly the same size as the direct output from DVDx 2.2. But file 2 was 23 bytes smaller. All three files were input to SVCD2DVD and the output was AOK. There appears to be some sort of problem with the second MPG out from DVDx 2.2. This is not an isolated instance as another set of MPGs also produced the same result.
So for now the solution is to use only ripped MPGs as input to SVCD2DVD.
I don't know how the author of SVCD2DVD will handle this problem. It would be nice if he could come up with a fix since there are instances where using direct output from DVDx 2.2 would be most advantageous.
Researching this problem identified another change to SVCD2DVD that would be very nice. Provide the capability to create the DVD VTS folder with _DVD files that have already been created so it is not necessary to go through the DeMuxing/ReMuxing process all over. This would provide an easier way to recreate the DVD VTS folder if you wanted to change the menu for some reason or wanted to change the makeup of a DVD. Just something for the author to think about. -
Well I'd never even heard of this application until now. SVCD2DVD works best with SVCD mpegs which comply with IEC 62107.I don't know how the author of SVCD2DVD will handle this problem. It would be nice if he could come up with a fix since there are instances where using direct output from DVDx 2.2 would be most advantageous.
Indeed I have been thinking about this for sometime. The trick is that the mpegs must be multiplexed to a certain structure in order for the authoring to work. I assume nothing currently & so remux to ensure compatability. I have two options here: ask the user or "sign" mpegs which have been muxed by svcd2dvd proviuosly. I'm looking at the latter as my users base has a huge range of ability & understaing and i want to take such decisions away from the user.capability to create the DVD VTS folder with _DVD files that have already been created so it is not necessary to go through the DeMuxing/ReMuxing process all over. This would provide an easier way to recreate the DVD VTS folder if you wanted to change the menu for some reason or wanted to change the makeup of a DVD. Just something for the author to think about.
Thus going forward you should be able to fire up SVCD2DVD and maybe have an ability to drag & drop processed sources on to the author tab and go from there....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Want to start a new topic and indicate which guide you are on about? If the dvd folder differs care to let us know how?
Svcd2dvd
By dobbin in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 24th Jan 2011, 12:19 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
Growing Flowers video clips
By MI6 in forum EditingReplies: 2Last Post: 2nd Sep 2010, 03:29 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 27th Sep 2009, 13:41 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 26th Jun 2008, 00:58
