It has been awhile since I defragged my HDD and it is becoming noticeable when I watch DivX movies (think of a badly dubbed movie). Anyway I thought I would finally get around to doing it but need some suggestions for a good freeware/shareware degragment program.
I was using Diskeeper but that screwed up and before that Norton Utilities. So what program do you use and would you recommend it?
Results 1 to 11 of 11
Whats wrong with the windows one
Nothing wrong with the Windows one, and BTW in 2k or XP the drag problem is a stripped down licenced by MS version of Disk keeper. But I've never had a problem with defrag.
You tried FDISK ?....
:P
Seriously , I used to use http://www.vopt.com/VoptXP.htm
this, but since i now have my video on a seperate drive i simply burn it to CD/DVD and format the drive. Rarely defag now because most of my files are on seperate partitions/drives from the OS.
I just use the Norton one because I can customize certain files to be on the inner or outer portions of the platters. I'm sure there are others that do this as well but since I've got SystemWorks I may as well use it. Nothing wrong with the Windows defragger, but I'm not sure if it rearranges files like the Norton one (less frequently-used items go to the end of the line). Not even sure if it really makes a difference. I defrag each drive once a week and I suggest people do the same. You can schedule it to do it while you're sleeping if you wish.
Yes agree diskeeper lite better than m$ as it is much quicker. A good idea to defrag on regular basis as ordinary internet use leaves loads of small files around. Downloaded files are normally very very fragmented. Copying a large file from one physical disk to another will tend to put it into one clump as well.
OO is the best hands down ..Originally Posted by stiltman
norton (except for ghost) anything tends to screw a system up somehow almost everytime ... though speedisk isnt that bad i understand .. norton = king of bloatware though ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_MWhat Experts Say - MCP Magazine
"Hands down, O&O Defrag is the best defragmentation tool I've seen to date. ... For my money, I'd go with O&O."
Joseph L. Jorden, Chief Technical Officer for Dugger & Associates
Read article
I've been using it ever since I went from win95 to NT4 then to Win2K
I do like diskeeper too, but I only use it on my servers
I'm looking for a good DVD Authoring program. Need suggestions please.
By LegendaryGamer in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2010, 20:35 -
Webcam Capture Program Suggestions Please
By gtrgriff3 in forum Video Streaming DownloadingReplies: 9Last Post: 16th Jan 2009, 10:27 -
Suggestions for DVD > Audio program?
By tac7 in forum AudioReplies: 10Last Post: 10th Jan 2009, 14:38 -
Found useful program to defrag page file
By jimdagys in forum ComputerReplies: 2Last Post: 11th Oct 2008, 06:43 -
program suggestions
By Kibble in forum DVD RippingReplies: 15Last Post: 7th Mar 2008, 15:52
