OK. I finally figured out how to use Adobe Premier. Now that I have completed my project, I exported it as a movie and ended up with an AVI file. When I go to burn it with Nero 6.0, the timing of the slideshow is totally off from the music. Should I be burning this in a different program. Please Help!
Hi,
When you say "burn" do you mean to a DVD? If so, you need to export the movie as an Mpeg2.
Export Timeline-
Adobe Mpeg Encoder -
Choose DVD template and then export or Edit in order to adjust the DVD settings.
You'll get a much smaller mpeg file, which will burn correctly to DVD.
Bill
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 06:02 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 22:01 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 12:57 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 21:55 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 10:29
