I have a mpeg of, lets say 745 Mo. What can I do to reduce its size or shrink
it so it can enter on a CD of 700 Mo (I'm writing from Quebec, Canada and we don't have 800 Mo Cds) ? Let's say I want a size of 600 Mo or maybe 150 Mo? What can I do and which program do I have to use to do that?
Randy West
options:
1)enable overburn on your cd burner (may screw up burner)
2) clip the video and beginning and end
3) cut the file into two
4) reencode the video to fit 600 or whatever mg -
you can fit an 800MB MPEG on a 700MB CD without overburning.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
That's if you're burning it as a vcd or svcd which use mode 2 burning (no error correction).Originally Posted by Ejoc
If you're just burning it as a data disc then it's 700 MB on an 80 min. CD max."Art is making something out of nothing and selling it." - Frank Zappa -
why not burn it as mode2? you can still copy it off the CD.
Ejoc's CVD Page:
DVD:
Capture:
4:3 to 16:9 without reducing quality
By trickytree in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jun 2009, 19:06 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22 -
Reducing frames with Staxrip
By jaysonp in forum Video ConversionReplies: 3Last Post: 4th Mar 2008, 11:32 -
Help with reducing size
By gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 14:17
