  1. I tried backing up the Bonus Disc with DVD Fab and DVDXCOPY and, as I had predicted, the result is failure.
    These programs expect the DVD to contain a large "main movie" but all it contains are a dozen small movie clips. It copies the largest small movie into the Disc One output, and tries to cram everything else into Disc Two output. The result is that Disc 2 output folder has >4.34 GB.
    Any other way to backup the BONUS DISC into two DVD-R including full menus?
    One option would be DVD Shrink and just convert some movie clips into still pictures.
    I would much rather have the "Please Insert Disc 2" change graphic screen associated with DVD Fab and DVDXCOPY.
  2. Do it manually as per the instructions on my webpage (URL in sig).
    http://encoding.n3.net <-- for all your DVD and CD backup needs!
  3. mattcham
    use dvdshrink or dvd2one for the bonus DVD, i used dvdshrink....
    for the main movie (DVD1) never ever use dvdshrink or anyother shrinking programs!!
    LOTR_TT the movie quality is so perfect that you need to re-encode it !
    i am right now re-encode it with CCE 5Pass for maximum quality to fit on 1 dvd-r...7hr so far...
    if you want speed over quality use dvd2one or dvdshrink
    for quality use CCE....
