I am about to order an American DVD as I live in Australia and this particualr movie isn't released here. Its for a fathers day present and i wonderred if i can import it, rip it, and burn it in the Aussie Region. I have a sony dru510 +- DVD Burner. Any information would be much appreciated.
It's pretty easy to change the region. I'm in the US and renting lots of
Region 2 DVD's and I rip them using DVD Shrink and DVD Region Free
and burn them using Nero. DVD Region Free tricks my burner into letting
me change the region. But I still have to use a region-free DVD player
to play it back because of the PAL --> NTSC problem.
So it depends on if you just need to change the region which is pretty
easy or change from NTSC to PAL which is pretty time consuming. -
from the looks off the dvd i want to buy, its ntsc (Region 1) and in australia we use Pal (Region 4). i.e. i assume im going to have to convert it to pal? how would i go about doing this? thanks
Most if not all Australian DVD + TV equipment can play back NTSC material just fine. Don't convert to PAL unless you have to.
Regards.Michael Tam
w: Morsels of Evidence -
NTSC doesnt mean Region 1, and PAL doesn't mean Region 2 or 4.
Just remove the region and it will play OK.
Just rip it to your HD with DVDDecrypter and it removes the rerion code automatically.
I've done it hundreds of times. -
Please post dvd to dvd in our dvd to dvdr forum. I'm moving this one.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 11:49 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
