i make my vob files with tmpgenc dvd author, now i want to delete or never see themenu beoing created by it though, i wanna use those vob files in ulead dvd movie factory 2, so what im saying is what other program avaialable on this site can make vob files directly from dvd compliant mpgs, and even if i do it with ulead, will the menu show up that was created with tmpgenc...holla back.....
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Isn't there a way to author in TMPGENc without having to have a menu? I know in DVD-Lab and DVDComplete, you don't need to have a menu, the first play will be the movie.
Other than that, the VIDEO_TS.VOB is the first play item, so if that happens to be the menu, than just use the other VOB files and ignore the VIDEO_TS.VOB. -
Just choose no menu when you author it in tmpge dvd author. It will play the movie first thing.
k..i know that selection the both of you are talking about, but if i load those vob files i to ulead dvd movie factory 2, can i create a menu with that program...holla back
k..i will continue my question after i have tried...
I believe you just load the 1 file into MF2 and then change the option to play first. By default it will not show a menu (unless the user presses the enu button) The only other things would be to use IFO edit, or just have nero burn it.
Wonder if dvdshrink could pull it off?But it actually needs an ifo file though -
im gonna try it in ulead right now and see if i can load the vob files and crete a menu.........
