Ok, there is a new -K option in mpeg2enc:
I am hopeing this will be configurable in ffmpeg 0.0.8, but if not maybe it is something you could squeak in?There is a new commandline option --custom-quant-matrices (short form
is -K) that takes 1 argument:
--custom-quant-matrices|-K kvcd|tmpgenc|default|hi-res|file=inputfile|help
sample uses:
-K kvcd
-K tmpgenc
and lastly the ability to load complete garbage (if you desire)
into the encoder by creating a file (format described below):
-K file=/tmp/fendt
The format of the file is quite strict (I didn't feel like including a
big/fancy parser into mpeg2enc): The INTRA matrix is first, the
NONINTRA matrix is second. There must be 8 comma (decimal) values
per line with no trailing characters (extra commas, comments, etc).
Blank lines and lines starting with '#' are ignored.
Guest
mpeg2enc.
By zaque2004 in forum ffmpegX general discussionReplies: 49Last Post: 4th May 2014, 05:02 -
How to download mpeg2enc
By drubiolo in forum ffmpegX general discussionReplies: 2Last Post: 20th Sep 2009, 09:04 -
i can't get mpeg2enc to work??
By dyevers in forum ffmpegX general discussionReplies: 1Last Post: 25th Jun 2009, 12:16 -
mpeg2enc
By Corelogik in forum ffmpegX general discussionReplies: 2Last Post: 26th Oct 2008, 11:07 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07
