what is the best basic software to clip and fade mp3s?
loooking to clip a mp3 with a fade
wondered what was the easiest way of doing this?
I use the Nero Wave Editor (works on MP3 as well as WAV, and has fade, cut, all the functions you need) in the Nero Burning ROM program, it is included as part of the program (I think it's in v.5.5 as well as 6.0). There are other audio editors out there, such as Cool Edit Pro, Sound Forge, etc. but just for basic editing you can't beat something like Nero. I think there is a similar function in Easy CD Creator that will do the same thing.
Ethernet (n): something used to catch the etherbunny
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 17:36 -
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 13:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 09:23 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 19:03 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 21:58
