http://forum.alcohol-software.com/index.php?act=ST&f=1&t=5584&s=98616221f69bb5ff03658841c797c690
http://www.dvd-secrets.co.uk/phpBB2/viewtopic.php?t=27046
ok so to break it down simply............
1. create MDS file for your pdi images.
2. mount your MDS file in your virtual drive.
simple huh?
Cheers
KYUSS
For some other options:
Pinnacle also has a virtual drive product that let you mount it's images. It comes with Instant cd/dvd. I havn't used it (yet). It may be in the download trial. MRBass also has some tools in his guide to go from pdi2iso. Then you could mount with Daemon tools.
--- Edit ---
I wrote the reply before I read your linked thread with the guide.
Was a better description. Probably much faster than downloading the "huge" instand cd/dvd trial.basic steps
1. create MDS file for .pdi images using dvddecrypter
2. mount MDS file using your virtual drive.
I mean it in the nicest way. -
Originally Posted by ImaWeTodd
lo m8
thanks for reply
1. tried pinnacles virtual drive (Instantdrive) and it never worked!!!! that came with instantcopy 8.
2. my guide was written as an alternative to converting pdi2iso or pdi2files m8......as they are both time consuming and tie up my computer.....where as my method is pretty instantaneous!!!!
3. yes u can mount ISO's with daemon and the next release of daemon will have the abilty of mounting .pdi images included
i think my method is fast and easy once u have done it once.........although i am informed that it doesn't work with daemontools for the mounting stage only Alcohol 120% so far.
cheers
KYUSS -
I think your method sounds tops.
Unfortunately, I opened my mouth before I read the whole other thread.
The second link does require registration.
Great Tip !
ThanksI mean it in the nicest way.
Are there desk mounting clamps for hdtvs? Not wall mounting but a flat base
By yoda313 in forum Newbie / General discussionsReplies: 12Last Post: 2nd Oct 2011, 18:24 -
Mounting virtual images under Windows 7
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 16th Jan 2010, 00:50 -
Problem with Alcohol 120 mounting images on system start
By Talayero in forum ComputerReplies: 1Last Post: 29th May 2008, 11:53 -
TV mounting
By Lucifers_Ghost in forum Off topicReplies: 11Last Post: 12th May 2008, 20:27 -
Vertical mounting problems
By AlanHK in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 11:17
