Hi guys
Sorry to keep posting abput pauses, don't get anoid. But its driving me crazy!
Basically I copy a movie onto dvd-r successfully, play it on Yamaha s520 and say it pauses at 44mins into movie, if I rewind back to 39mins and start watching again, it won't pause at 44mins etc, you see what I mean.
I have already been told about how their should be no pauses, except for one brief one on dual layer discs.
So can I presume that my copies are alright if pauses are random, and that the problem actually lies with my dvd player.
If so if (can) I upgrade its firmware, and will this solve the problem? Thanks. Also I don't believe problem is related to cheap media either as pauses are random!!
help me!!!
thanks
steve![]()
Inadditon problem only occus with copied dvds, not originals! So that tells me that maybe player is not broken and is OK!!
Im going round in circles!! -
It sounds to me that it is probably your dvd player. Try upgrading the firmware, or get a new one
This sounds like bad (cheap) media. What brand are you using? I have tried princo, memorex, dvd-on, bla bla bla. I have finaly found Ritek. They work great for me. However, pioneer and maxell brands worked but were too expensive.
I agree with FT Shark, it certainly sounds like a media problem.
As mentioned try a good quality Ritek disk. Princos are often troublesome and are not so widely compatible with standalone players.
I'd put a little wager you are using Princos
DVD Architect - Pauses between titles, why?
By mjvgiese in forum Authoring (DVD)Replies: 2Last Post: 25th May 2010, 00:12 -
DVD video pauses every 30-35 seconds
By LoopyCoder in forum DVD RippingReplies: 0Last Post: 9th Apr 2008, 14:43 -
Finished DVD pauses for a second every 30 seconds
By shamrockbar in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Mar 2008, 12:19 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33 -
Sony DVD Architect 4: Long pauses between video titles
By mltwitz in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 19:39
