I apologise in advance if this has been discussed, i did search for ages without much luck. I just want to know what is the best way to do it, what progs you guys use to do this as there are so many it makes your head spin! do i have to extract the mpg files and join them, then author or is there better ways? thanks for any help guys![]()
Growing old is mandatory......growing up is optional ;0)
Check this one (didnt work for me but might work for you).
https://www.videohelp.com/svcddvdr.htm
Or this one which is adapted from the guide above and did work for me and some others.
http://www.geocities.com/unicornial2003/
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Burning mutiple files
By Canary in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2010, 10:46 -
Mutiple (30+) AVI's to DVD; DVD plays only the first 15
By sudiptoghosh in forum Authoring (DVD)Replies: 2Last Post: 12th Apr 2010, 10:56 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Opening crawl of star wars a new hope shows mutiple languages
By tschroeder250 in forum DVD RippingReplies: 5Last Post: 22nd Dec 2008, 00:34
