  1. I created a .bin and .cue file with VCDImager and when i load the cue into NERO 5.5, it thinks it has 3 tracks, totalling 900mb, when it should be only 1 track, 300MB. I put 2 SVCD clips in VCDImager (150MB each).
    Any ideas?
    JTurbo
  2. Edit:
    I made an error in my previous post ... VCDImager created 3 tracks, pointing to various times in the bin. The total size of my bin is 300MB, yet Nero seems to think that each TRACK is 300MB ... thus trying to create a disc that is 900MB.
    JTurbo
  3. hmmm. any image i use nero to burn doesnt fecking turn out at all. that is any VCD image.
  4. I had the same problem with Nero 5.5, but no problem with Nero 5.0
    Looks like a new Nero bug.
    Try using the older version of Nero.
  5. Using Nero to burn CUE/BIN images of VCDs is a bad idea... It doesn't correct burn the disc can can lead to all sorts of problems (especially if menus are used).
    There is a page on the VCDImager website detailing what Nero does incorrectly.
    I strongly suggest that you use a proggy that can understand CUE/BIN images, ideally, CDR-Win. Fireburner and CDRDAO are also alternatives.
    Regards.
    Michael Tam
    w: Morsels of Evidence
