Hi. At the moment I am using Nero to make my copies, as I live in the UK is there anyway I can make certain they are being done in the pal format, or do I need another program to convert them to pal.
Cheers thespook
If they were PAL to begin with, they'll be PAL when you copy them.
If they were NTSC to being with, they will NOT be PAL, they will be NTSC.
You would have to RE-ENCODE them, not convert them. It's a length process which we cover at least twice a week in here. Read through the backlog of posts.
- Gurm -
Also .... unless you have a really old TV or cheapo portable, most DVD Players/TV's are multisync these days and will play NTSC or Pal, so it shouldn't really be much of a problem.
Thanks for the quick replies. I am not a 100% sure that is the problem, a friend has a Kenwood standalone player, it seems to play some DVD Rs but others it will not even using the same media, so I thought it might be that it wont accept ntsc.
thespook
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
I need PAL format help...
By jenn00_v in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2009, 16:29 -
Any S/W Players that will play PAL format clips ?
By Seeker47 in forum Software PlayingReplies: 2Last Post: 17th Sep 2007, 14:10 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26 -
Actual format PAL??
By KingBongo in forum ffmpegX general discussionReplies: 5Last Post: 11th Jun 2007, 06:29
