  1. tophope
    Guest
    To create a DVD than the old version did.It used to take between 40mis and 1 hour, now it takes over 4 hours.Am i doing something wrong ?
  2. Guest
    something must be wrong. For me it's taking the same amount of time as it did with the old version... about 40 mins.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    One thing I noted. This version seems to be more prone to fragmented HDs. I did a 5 bin 2 dvd and it took 3hrs+ After I cleaned up my HD (burnt & deleted the 10 or so dvdfolders i had pending) and defraged it then was the same as last version....
  4. I had the same problem so I degragged my drive.
    Didn't make any difference. Still took a very long time.
    Any Ideas?
