Hello,
I have a PIII 500 with 300 Megs memory, I have the ati TV tuner card, a CDRW drive and both NERO and Easy CD creator.
I have been making VCD's for a while now. The way I do this is use the ATI software and check on capture for VCD. Then I put it on a cd using easy CD 5.0.
My problem is the quality on the Television is not great. I am told that SVCD is much better. I have not idea how to capture video for SVCD. I am assuming I will also need to use NERO to burn it on a CD which I have.
If anyone can give me some advice I would appreciate it.
Results 1 to 1 of 1
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 12:27 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
