Is it possible to burn on a dvd device several vcd instead of burning different cds? Are the normal home dvd able to read it?
Help me please
rimbaGuest
rimbaGuest
Thanx ImaWeTodd, but I am searching how to do it with my OS X... does it exist a mac program similar to SVCD2DVDMPG?
Thanx a lot
Rimba
The registered version of ffmpegX 0.0.8 is able to do it. First check if your player is compatible with "VCD-DVD" by looking at the DVD players compatibility list.
Then put your VCD files in a folder, and use the "S/VCD > DVD" tool of ffmpegX 0.0.8 to automatically reauthor them as one DVD without re-encoding the video.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
