I am still a little confused about the DVD+R vs. DVD-R battles, but I do know that my DVD player has read a DVD+R in the past. It went crazy once when i tried to read another DVD+R, but it worked atleast once. I mainly use a Sony Playstation2 to view DVD's, any advice?
Now, I am about to buy a burner, but am looking for the best choice, and for a good price. I thought that buying a burner that would burn onto DVD+R and DVD-R would be the best thing to do. Are their any burners that do this? If so which? I am looking at a few burners that just do DVD+R that I can get for around $100-$130. I am in the US BTW.
Go for the dual-format burner. Several dual-format burners are avaiable for under $200.
Here is a sample from avlogic.com...
The Pioneer DVR-106D at $159.00 at avlogic.com.
The NEC ND-1300A at $130.00 with no software and $141.00 with software,
The Optorite DD-0203 at $179.00,
The Sony DW-U10A at $165.00 with no softare and $167.00 with software,
I recommend the Optorite (I own two of them) but the other three should be just as good. I've heard good things about the NEC and Pioneer, but I hven't heard much on the Sony, so it maybe a newer model... -
Does anyone have any idea about what formats will work with the Playstation2? Like I said, mine read a DVD+R 1 time, but went crazy when i tried it again.
check out this link to PS2 compatability: https://www.videohelp.com/dvdplayers.php?DVDname=playstation+2&Submit=Search&Search=Search
So far mine has played every DVD-R that I have thrown in it.Does anyone have any idea about what formats will work with the Playstation2?
SLICK RICK
Blu-Ray Burner Advice Please
By leebo in forum DVD & Blu-ray WritersReplies: 25Last Post: 22nd Sep 2012, 12:49 -
DVD burner advice please! Good current models?
By Bubblevision in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Dec 2011, 08:04 -
Need advice about buying a Dvd-R DL burner
By southrngntlmn1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd Apr 2008, 13:12 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 05:09
