  1. Could any one help me plz. i am trying to put four dvd films on one dvd-r disk, and don't no how to do it.
    Could any one help plz..
    ²ºº³(¯`·._.·[ANGELUS]·._.·´¯)²ºº³
  2. Read the guides to the left for help in using various programs. How long are the movies? You could use DVD Shrink and compress the movies down, but the quality would be total crap, so wouldn't be worth your time
    "Can You Dig It!"
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Using the guides in the How To: DVD Rip section, convert each of your movies to an mpeg-2 file, at a bitrate so they are no bigger than 1.175 GB (4.7Gb divided by 4 movies).
    Then, using the guides in the How To: Author, import your movies into a dvd authoring program, make a menu so you can select your movies, add chapters, and compile your dvd.
    then burn your compiled dvd with your preferred burning software.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  4. Thanx for the info. and the help lads
