Hi guys,
if i want to change my buner, is it simply a matter of opening case pulling out old one & installing new one?? sounds simple but is it really that simple
also my burning software (copy to dvd) doesnt seem able to select burn rate.
if I get say poineer A06 which burns dvd -r at 4x , but I use on 2 x discs which i have left, do they freak out or simply burn at max disc rate (ie 2x) regardless of software rate set to max??
cheers
Originally Posted by valian
SLICK RICKOriginally Posted by lordsmurf
Do you install software from the cd/dvd or go straight to the website?
By yoda313 in forum PollsReplies: 11Last Post: 18th Jun 2008, 14:10 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
how do install two folders video_ts in one dvd-r
By togood in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 05:58 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15 -
DVD playback software without install
By sugeknight in forum Software PlayingReplies: 4Last Post: 12th May 2007, 10:59
