I am having the strangest problem. I captured some VHS footage using DivX 5.0.5 and VirtualDub's capture. When I play the capture, everything is great. I wanted to convert it into a VCD, though.
First I tried to convert the file straightaway using TMPGEnc. The audio gradually slipped out of sync, such that the video cut off about 5 seconds of the ending audio. So...
Next I tried to separate the audio from the video using VirtualDub. Check out the lengths of both...identical. Then used TMPGEnc. Same result.![]()
Something told me that I should check the audio file, so I did. The recording was the same length as the video. I went to the end of the recording. It was missing the same 5 seconds!![]()
How can I be saving the WAV from a fully functional video and VirtualDub cuts the end of it off like TMPGEnc would?!?
As a solution, I can open the audio, manual record the missing part, paste the two together, resample it at like 44.2 kHz, then encode it. What a mess though!
Can anyone think of a simpler way of fixing this problem, or better yet correcting the problem at the source so the audio isn't cut off?
Thanks!
Could it be that the VCD (template?) you're trying to create has a frame rate different from the captured AVI?
/Mats -
I wouldn't think so. I captured at 29.97 (or whatever the NTSC VCD standard is). Still that shouldn't have any effect on the VirtualDub - Save to WAV function.
OK! I didn't see that - the audio is off in the AVI too. What happens if you capture in another format (like huffyuv)? Real time DivX capture/encoding seems like requiring a pretty hot box, and it may be that your system can't handle the load?
/Mats -
I thought about that. It can't be my computer (2.66GHz P4 with GeForce). I don't have any experience with other codecs, simply because I haven't had a need to use anything but DivX and MPEG. I will give that a shot though. I am pretty sure I have it on my computer.
I was able to get a copy of Sound Forge 6 and it is fantastic at resampling and time fitting. So if I can't figure it out, I will use it as a back-up.
Ok using the new DivX release, how do i capture, HD style?
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 9th May 2009, 23:35 -
Today only, Pinnacle hardware DivX capture box.
By olyteddy in forum Capturing and VCRReplies: 0Last Post: 7th Nov 2008, 09:56 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 24th Aug 2007, 23:49 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 14:11
